Nasty bug with tables (LV 8.2)
@Kravlor wrote:
... Is there some sort of mailing list we can be put on to find out when the official fix is released?
If you are on SSP, you will be notified automatically and shipped the new software. There's no other list to speak of, but I will set a reminder to update this thread when a fix is available. I can not preannounce when that will be, but I believe you will be pleased with the timing. Smiley Wink
Roy
Message 21 of 23
(953 Views)
LabVIEW 8.2.1 (which has a fix for the above problem) has been released. If you are on subscription service (SSP), then you've been shipped the new release automatically.  Does that count as a mailing list? 🙂
Refer to the following link for more information:
LabVIEW 8.2.1 for Windows - Compatibility, Bug Fix and Upgrade Information - http://www.ni.com/support/lv8_21.htm
Enjoy,
Roy
P.S. - We discovered a problem with upgrades after the release. It's trivial to fix, once you know about it ("once you know about it" being the key phrase). Please read the online version of the Upgrade Issues (via a link on the above page) before you upgrade (to learn about this problem and any others we learn about).
Message Edited by Roy F on 04-10-2007 04:39 PM
Message 22 of 23
(871 Views)
@bww wrote:
Just to follow up with my previous post, the work around that I suggested does in fact work, atleast for my application. Please see attached vi. It turns out that the crash only occurs with the table being an indicator and not a control.
Bryan
NO, LV 8.2 crashes even when the Table is a control. Today morning we tested it. In our application, we use the Table as a control since the user is required to fill it with 0s & 1s for 8 signals (rows) & desired Samples (N no of colums). We saw the same error number thrown out by LV 8.2, as mentioned earlier in this post.
But anyhow, we didnt buy LV 8.2 yet... relief... ! Smiley Very Happy
We may buy LV 8.2.1. Smiley Wink
- Partha ( CLD until Oct 2027 🙂 )
Message 23 of 23
(851 Views)
