Hi Everyone,
After a recent clean-up of my cupboards, I found a National Instruments PCI-DIO-96 Digital I/O Board which I am more than happy to part with (it was going to be part of a personal home automation project that just didn't get the funding!) I have never used this board - I took it out of the bag, but never got to plug it in...
The PCI-DIO-96 is a 96-bit parallel digital I/O PCI board with 96 lines (5 V/TTL) static I/O in 8-bit ports, 2-wire handshake capability, known power-up state (can be very useful!), and unidirectional & bidirectional I/O. This board uses four 24-bit programmable peripheral interfaces (PPIs). You can divide each PPI into three 8-bit ports. The PCI-DIO-96 is flexible for
interfacing to peripherals or other computers. The board can operate in either a unidirectional or bidirectional mode and handshake with peripheral equipment. NI usually retails this card for $US295.
Anyway, if you're interested in buying it from me, have a look here:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=2034332755
cheers,
Christopher
Christopher G. Relf
Christopher.Relf@mBox.com.au
Int'l Voicemail & Fax: +61 2 8080 8132
Aust Voicemail & Fax: (02) 8080 8132
EULA
1) This is a private email, and although the views expressed within it may not be purely my own, unless specifically referenced I do not suggest they are necessarily associated with anyone else including, but not limited to, my employer(s).
2) This email has NOT been scanned for virii - attached file(s), if any, are provided as is. By copying, detaching and/or opening attached files, you agree to indemnify the sender of such responsibility.
3) Because e-mail can be altered electronicall
y, the integrity of this communication cannot be guaranteed.
