National Instruments PCIE 1429
I am using a monochrome Basler Cameralink Camera(A504K)of resolution 1280x1024 with a card grabber PCIE-1429 (x4 slot). The image acquisition is controlled through MAX  of LabVIEW version 11.0.1. The problem is that when I try to reduce the number of rows(more specifically Height) from 1024 to 32(say)in the acquisition window(of MAX), the frame rate of the camera should increase almost upto 16,000fps. But it is not going beyond 248fps. Can you suggest  me, why is it so happening, Or How to increase its frame rate? Also, below the image window there appeared something like: 1280x32    1X   8-bit image  9. What does 1X actually mean here?For your ready reference I am also attaching the image of the acquisation window.
(2,998 Views)
I assume you will need to install Basler's CCT+ to configure the camera framerate via the serial interface of CL. To enable serial communication via CL you have to open MAX, go to Tools>NI Vision> Select CLSer Nat Systems.
Christian
(2,958 Views)
