Natural logarithm which curve fit to use?
Accepted by topic author Murph
This might have been more of a case of my poor explanation.
The attached vi solves the problem.
Now if I could only figure out how to plot a line from the start poit Y to the endpoit Y I'd be laughing.
Message 11 of 14
(800 Views)
What kind of line? According to the best fit? A straight line?
Message 12 of 14
(796 Views)
Spoiler
I'll try to explain.
The need for best fit was to determine a proper stop point. Once calculated we find the intersecting Y value there.
The end result is that we start at one y point on the baseline but finish on another.
The line I need might be easier to see in the attached pdf
Message 13 of 14
(794 Views)
Just generate another 1D array that contains NaN for all points outside the range and a liner ramp inside the range, the add it as a second plot to the graph using build array. That's easiest.
(A fancier solution would be using the "plot images" feature that allows using picture tools on graphs)
Message 14 of 14
(791 Views)
