Navigate from waypoint to waypoint (Trig fun)!!!
I am automating my boat with Labivew, in Alameda Ca)
I receive GPS data via bluetooth (Garmin Glo)
I communicate with my autopilot via NMEA communicated via TCP (Comar i320W)
Currently I just send heading data, and the autopilot changes to that heading.
Fun Times!!
Now I wish to tell it to go to a "waypoint" (Lat and long on an xy grid)
this takes high end trig that I forgot pre covid.
Any thoughts?
(1,542 Views)
Hi Chad,
Any thoughts?
Get a book on basic math (including trigonometry) - read and learn.
Then setup the formulas to convert from position/distance to heading/speed parameters…
(I don't think this will be "high end trigonometry"…)
(1,510 Views)
My first thought is that Latitude and Longitude are not coordinates on an XY (planar) grid, but are coordinates on a spherical surface.  Makes it an even more fun math problem, as the shortest distance between two points is part of a Great Circle whose center coincides with the center of the Earth (if I remember my math correctly ...).  I suspect that Spherical Polar coordinates are going to be involved sooner or later.
Bob Schor
(1,488 Views)
(1,437 Views)
Thank you, your input is valuable
(1,436 Views)
