Nec-Avio TVS-600 camera-pc msvcrtd.dll not found
Hi everybody,
I'm trying to connect a thermo video system camera, via IEEE1394 with a pc, in order to acquiring temperature values from a metallic stick, but when I open Labview (version 8.2) it tells me it's impossible to open the VI, because the lack of msvcrtd.dll in labview. It opens anyway but doesn't run. Where I can find it in the program directory? there's a way to replace it with a not corrupt one? If yes, where I can find the correct dll?
I've attached the file I can't open, it's an example, because every file of that kind (tvs vi's to acquiring temperature) doesn't work without this dll.
Thank you in advance for the help,
Best Regards
(3,077 Views)
Hi
where did you find the library to pilot the infrared camera (IrCamCmd.vi, etc)????
(3,028 Views)
I found it in the TVS Labview CD-Rom from the TVS supplier, I think it's impossible find it on the net
(3,021 Views)
