Neccesary files to distribute a DAQ Application
I would like to distribute an application with DAQ functions.
The application is in demo-mode. The vi's with the DAQ functions are loaded,
but they are not called in the program.
I would like to know what files I need (dll's, I suppose) to install and run
the application in a PC without NI-DAQ driver installed (and without an
acquisition card, of course).
Thanks in advance,
Miguel.
(2,729 Views)
Better way is to install the NI-DAQ driver on the target machine. I know that the main DLL needed by functions is "nidaq32.dll" but you need to install the driver on the target machine and this would also give you Measurement and Automation explorer (MAX) to configure the DAQ boards.
How i don't think that you would run the application without having the DAQ board physically in the system. The only way i could think of is add a Non PnP DAQ board in MAX and fake the driver.
Abdullah
(2,729 Views)
Abdullah,
Thanks for your answer.
Miguel.
Abdullah escribió en el mensaje de noticias
101-506500000005000000B6170000-981958153000@quiq.com...
> DAQ boards.
> Abdullah
(2,729 Views)
