Need 64bit Tabor WW1072 Drive
I bought a 64bit LabVIEW 2013. Now I want to work with Tabor WW1072 function generator. But the drive on the website is for 32bit system.(http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=9205 ) After I installed that drive, all the VIs in LLB file can not be run. The error show that the lib file is only fit for a 32bit platform. So I want to ask for a 64bit drive for WW1072.
(2,541 Views)
Hi DQZHU,
you might think about using a 32bit version of LabVIEW? Could be (a lot) easier than to search for a 64bit device driver…
(2,535 Views)
As this driver is apparently from the instrument vendor (at least, obviously NOT from NI), you might want to ask the vendor directly if there is a newer version of the instrument driver available.
The driver was created in 2006, included in the instrument driver network in 2009. So we talk about a driver, which is definetly untouched for 5 (!) years now, maybe even more than 8 years!
Norbert
Norbert
Expert: Geometry
(2,528 Views)
