Need Bluetooth DLL for PocketPC 2003 (LVBtw.dll)
Hi rberger,
You must install Hithe WIDCOMM Bluetooth DLLs on the Pocket PC device to run PDA applications that use Bluetooth communication as this is the driver supported in LabVIEW PDA. Samsung i730 uses MS Bluetooth Stack which is not supported in LabVIEW PDA module.
Tunde.
Message 21 of 27
(4,291 Views)
Hi Robert,
You must install the WIDCOMM Bluetooth DLLs on the Pocket PC device to run PDA applications that use Bluetooth communication. as this is the bluetooth driver supported in LabVIEW PDA module. Samsung i730 uses MS Bluetooth driver not supported in LabVIEW PDA.
Regards
Tunde.
Message 22 of 27
(4,291 Views)
Has this issue been resolved?
I'm having the same trouble: when I ran the setup to load the 3 bt drivers, the pda said "The program you have installed may not display properly because it was designed for a previous version of Windows Mobile software". And then I got the "unable to load Bluetooth library LVBTw.dll"
I'm using: i-mate JAM PocketPC     Windows Mobile 2003 2nd ed. v4.2.1088      LabVIEW 8.0         PDA module 7.1
I've tried manually updating the drivers, no luck. Also can't find an "about" menu to find out which bt stack is being used.
Any more suggestions?
Message 23 of 27
(3,673 Views)
In order to use the PDA module with LabVIEW, they will need to be the same version.  You can find version 8.0 of the LabVIEW PDA module at ni.com, by searching Drivers and Updates for PDA+8.0.
Let me know if this makes a difference at all.
Lauren
Message Edited by Lauren L on 02-04-2008 05:42 PM
Applications Engineering
Message 24 of 27
(3,444 Views)
"LabVIEW PDA Module Version 8.0 is no longer the current version and is not available for download.You may upgrade from an earlier version by using the online Upgrade Advisor utility"
The upgrade advisor doesn't offer earlier versions and suggests I pay £1500 for the latest copy of labview. Any ideas?
Message 25 of 27
(3,390 Views)
Hi grahamwebb,
You might want to contact your sales representative regarding to this issue.
Stanley Hu
Message 26 of 27
(3,122 Views)
HI,
Is the Bluetooth (MS BT Stack ) been solved? I try to run the simple Bluetooth vi. on my pda with error. I had even install the WIDCOMM Bluetooth in it. Stil no joy. Anyone please give me some help on this issues?
Info: LV 8.2, PDA module 8.2 and Toshiba e800 Pocket PC.
Thanks.
Message 27 of 27
(1,315 Views)
