Need Help Creating USB Driver on RoboRIO (or any of the Linux based platforms)
Hello all,
I need a little help.  I need to communicate between a DecaWave and my RoboRIO.  I posted a specific post about this in RoboRio DecaWave USB Driver but have not got any responses yet but this post is even more specific.
So I plug my device into my RoboRIO and it sees it but it shows up as "Not Present".  I am still trying to get a linux based but I am not sure I will get one.
When I plug the device into my PC I get a broken port (see Below) until I install the drivers from ST Microelectronics and then all is well.
I have read and went through most of the tutorials for creating a VISA Driver using "NI-VISA Driver Wizard" and at a minimum I should be able to see the raw data and then I can parse it out myself.
My Question is how do I create and deploy this driver for the RoboRIO?
(2,726 Views)
Hello GeneHancock
Have you tried to right click in the warning and update driver? What is the driver for the DecaWave?
Regards
(2,646 Views)
