Need Help Creating a Student Attendance VI
Sounds like a sketchy attendance counter.  I'd just pay my buddy to push my button for me.  You probably should use a retinal scanner instead.  Smiley Very Happy
Sounds like an easy assignment.  However, I cannot open 2018 files to see what you have written so far.
aputman
Message 11 of 18
(1,075 Views)
Start with a piece of paper and write down the steps.  Create a flowchart of how your program should work.
One key feature your VI is missing is a while loop that keeps things running.  You will probably want an event structure that acts on events such as the value change of a button.
I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
Message 12 of 18
(1,073 Views)
I saved it as a previous version for you. If you could show me how to make it read the data and count the missed days that would be awesome. This is the only thing stopping me from continuing my class project.
Message 13 of 18
(1,038 Views)
In order to count the missed days, you will need some way to know how many days the class assembled.  For instance, the teacher is there every day.  Is the teacher required to press a button or could that be added as a requirement?  If so, compare each student attendance to the teachers attendance and count it up.
I would recommend that you learn about state machines and event structures, as has already been mentioned.  This will give your code a foundation to build on rather than just having a bunch of random loops on you block diagram.
aputman
Message 14 of 18
(1,035 Views)
Why did you create a new topic on this when you already have one posted?
Re: Need Help Creating a Student Attendance VI
Message 15 of 18
(1,016 Views)
Now the threads are merged.
Message 16 of 18
(1,005 Views)
I am trying to get this to work, but I cannot make it work. Could you modify my VI for me?
Message 17 of 18
(989 Views)
Hi bjb,
as has been said before: we will not do your homework!
Attachy our VI, even when it doesn't work.
Explain where you fail. Explain what you want to achieve.
Ask specific questions…
Well, we could - but that is not the purpose of your homework!
Message 18 of 18
(975 Views)
