Need Help Implementing Ramp Function for Kikusui Electronic Load PLZ205W in LabVIEW
Hello LV Experts,
I am a student, and your guidance is invaluable to my studies. I am working with a Kikusui Electronic Load PLZ205W and have installed the kiplz5w instrument driver in LabVIEW for controlling the device. I have successfully established a connection with the load and can operate it in constant current mode, as well as enable and disable the load.
However, I need to implement a ramp function because the driver does not have a built-in function for this.
Example Requirement:
  • Ramp to 5 A with a ramp rate of 0.1 A/s.
  • Then ramp to 2 A with a ramp rate of 0.2 A/s. (so on)
  • I would like to input the target current and ramp rate from the front panel to make the functionality flexible.
I understand that this involves incrementing the current in small steps over time, but I need advice on the best way to achieve this using LabVIEW's programming structures (e.g., loops, delays, etc.) and the driver commands.
Any guidance, tips, or example implementations would be greatly appreciated. Thank you for contributing to my learning journey!
Message 1 of 30
(2,782 Views)
It might be hard to get a true ramp if that is not a built in function of the load. You can step the current by setting it in a loop but again you will be limited by the response time of the load. Perhaps you can empirically determine the step time delta that approximates a ramp.
______________________________________________________________
Have a pleasant day and be sure to learn Python for success and prosperity.
Message 2 of 30
(2,738 Views)
Hi Jay,
Thank you for your reply. Can you please elaborate on how to determine the step time delta?. I am confused on how to implement the loop. Thanks in advance :')
Message 3 of 30
(2,708 Views)
Here is an example of how to set current values in a timed loop. Replace the VISA VIs with your KIKUSUI driver VIs (I don't have that driver)
Message 4 of 30
(2,690 Views)
Hi Jay,
Inserting each ramp value to the array is very time consuming. Is there any other simpler way?. Also I didn't understand the use of that flat sequence. Thanks for helping :')
Message 5 of 30
(2,631 Views)
Hi Varghese,
LabVIEW has a Ramp function: open QuickDrop, type "ramp"…
The sequence frame enforces DATAFLOW, so it makes sure the wait is executed AFTER VISAWrite and BEFORE VISARead.
You can use the Stall.vim in your recent LabVIEW version instead.
Or you can get rid of that wait at all when your driver VIs implement a proper communication scheme with your device! (In this case any "message read" in the driver will wait for correct responses without needing additional waits.)
Message 6 of 30
(2,627 Views)
Hi GerdW,
Thank you for the clarification. I can't find the LabVIEW ramp function. I see a ramp function for IviACPPwr Driver but I am using kiplz5w Driver (when I try to use, it is showing "Wire class conflict" : refnums are different) .
Message 7 of 30
(2,619 Views)
GerdW is probably talking about this signal processing function.  I don't know why it would not show up in your quick-drop, but I think you do need the Advanced Signal Processing toolkit.
LabVIEW Advanced Signal Processing Toolkit Download - NI
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 8 of 30
(2,599 Views)
Don't let the Ramp Pattern.vi stop you though.  Creating a simple loop to build an array of steps with inputs of start, stop and #steps should be a simple task.  Try it and let us know if you get stuck...
Message 9 of 30
(2,598 Views)
I have a VI that does basically what you want. Instead of ramping from a rate of 0.2 A/s. How about: " I need to Ramp from 3A to 5A in 2 seconds". Convert if necessary. My VI rebuilds the ramp if the inputs change. But you could probably write something simpler
In the screenshot below I have a ramp function with feedback nodes for sudo state machine. You VI needs to keep track of.
  • What was the previous current Target? A(t)
  • What is the transition time (Or use transition rate and convert)
  • What is the new Target? A(t)
  • How much time has passed? A faster loop rate will give you a higher resolution
Message 10 of 30
(2,585 Views)
