Need Help Installing 8.6.1 Upgrade
I just recieved my Q1 2009 software up date!  As I go to install it(from the DVD), on a vista machine, with 8.6 already installed, I recieve th folling error:
" Error:  Windows SDK function returned and error. (Error code -12)  The Handle is invalid."
Any Ideas?
(4,053 Views)
Hi Gene,
Are you still getting this error?  Do you get the exact same error message every time you try reinstalling 8.6.1?  Also, could I have a screenshoot of the exact error message that you are seeing?
Justin Parker
Product Support Engineer
(4,018 Views)
Actually after rebooting and removing and reinstalling the disk a couple of times it worked.  Maybe some sort of CD Rom drive issue?  Thanks for you help!
(4,012 Views)
That's great to hear!  Thanks for keeping me updated.
Justin Parker
(3,983 Views)
I need simple to install 8.6.1 from new DVD - setup program must correctly upgrade 8.6 to 8.6.1
Do I need to reactivate Labview (I have Base version)?
(3,949 Views)
Hi hellboy,
You will have to reenter your serial number and reactivate LabVIEW when you upgrade.
Justin Parker
(3,910 Views)
