12-27-2006 12:17 PM
12-27-2006 12:30 PM
12-27-2006 12:38 PM
12-27-2006 01:00 PM
Sorry, you're not helping us solve the problem. Descriptions such as "goes crazy" and "goes off" are meaningless. Does it always happen exactly after 7 minutes?
If the program is still running after 7 minutes, switch to the diagram and enable execution highlighting. You should be able to figure out where it gets stuck.
If you temperature reading strongly depends on sampling rate, something else is terribly wrong. Could it be your sine is an alias of the 50Hz power supply?
Why don't you attach your program? It would really help! 🙂
12-27-2006 02:00 PM
12-27-2006 02:48 PM
