Jared, Thanks for the sample. I appreciate the effort!
I was eager to try it, but unfortunately it won't compile when targeted for the PDA. It generates some errors I've not encountered before. Here they are in order.
Unsupported prim - BuildPath
Unsupported node - PropNodeMeth 94852
Unsupported node - PropNodeMeth 5184
Error creating temp dir in CreateDirCpyFiles
I know my PDA stuff is OK, because I can compile the Advanced example and all my other code I'm working on. These types of errors usually mean an attempt was made to use something not applicable to the PDA.
I'm still working on paring down the advanced example, because this one will compile. I can't believe they provided such a complicated exam
ple for such a simple feature. The Advanced example has record,pause,file open,save etc. that I just don't need. It also uses a rather complicated case engine that is somewhat overwhelming for a newbie like me.
Thanks again for the attempt.
-Bruce
