Need Help to set up a WSN using Labview
Me an my team are working on a project involving wireless sensor networks. At the moment we got the WSN starter kit and the software that comes with it (module pioneer) and we managed to connect the gateway to the nodes and receive data. Now we are faced with some questions:
1. How to send data from 1 node to 2 relays?
2. How can I configure a relay to send 50% of the time? (probabilistic approach)
3. Can I configure a Node to act as End Node or Mesh Router using labview or it can only be done using MAX?
4. Can I control the power transmitted from the nodes?
Thanks.
(2,606 Views)
1. As far as I can tell, a node can only speak to one relay. I'm assuming you are using the term relay interchangebly with Router
2. What do you mean by 50% of the time? Relative to what?
3.  I am familiar only with using MAX. Is there a reason you need LabVIEW specifically?
4. What do you want to control exactly?
Ben D.
(2,581 Views)
