Need Help
Property notes with what property ??
Message 21 of 29
(1,994 Views)
Property node.  The value property.
I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
Message 22 of 29
(1,980 Views)
Property nodes are very much like a local variable in concept. If you write click a property node (value) you can change it from read to write. If the node is on "read" then when the property node reads a value, it will update the value of the origional item that its property is for. If you change the property node to the write direction, then the property node will have the value of your origional item that the property is for, but the property node will only output the value of that item. Hopefully that makes sense.
There are two types of property nodes, one is value and one is value signaling. The value signaling is useful when you are using event structures and you do want labview to act upon an event change that deals with the value change.
Hopefully that made sense.
Message 23 of 29
(1,967 Views)
Oh i know about the read and write . what im asking is what property should i use . the disabled , visible?? because i cant connect . i don't know why . is it possible to show me example . ?
Message 24 of 29
(1,960 Views)
Message 25 of 29
(1,959 Views)
Value
Message 26 of 29
(1,957 Views)
got it thanks .
Message 27 of 29
(1,954 Views)
Is it possible to put a save button , where it captures the image of my waveform . ??
Message 28 of 29
(1,932 Views)
Message 29 of 29
(1,902 Views)
