Need LabVIEW DSP Module version 2.0
Hello, everybody!
I have the following issue. We have a SPEEDY33 device and LabVIEW 8.2. As I've understood the SPEEDY33 works via DSP Module. But I can't find and download the DSP Module version 2.0, which is compatible with LabVIEW 8.2 (according to this table). The question about DSP was discussed here, but the link given there enables only to get the DSP 8.6 version, which is uncompatible with our LabVIEW 8.2 and even the registartion of the device doesn't help to obtain the required link. So does all these mean that I won't be able to work with SPEEDY33?
Thanks in advance, Anton
(2,977 Views)
Accepted by topic author AntonF
Hi Anton,
You will not be able to download DSP Module 2.0 from our website. You can try contacting your account representative by calling (888) 280-7645 and see if DSP Module 2.0 CD can be mailed to you. Please note, there maybe a charge associated with getting this CD.
Arham H
(2,951 Views)
