Need OLE Execution Method.vi
I would like to know if a VI "OLE Execution Method.vi" was included in Labview versions 4 and below. If there was, what has it been replaced with?
I would be really grateful if someone could provide me with this small piece of information. Thank you very much.
(2,816 Views)
Elle -
Being able to access the vi palette from LabVIEW versions prior to 4 would be a near astronomical task.  What are you trying to do with this information?  If you are looking to upgrade from an older version of LabVIEW please reference my note below:
LabVIEW 6.0 and later no longer contain the OLE VIs previously located in C:\Program Files\National Instruments\<LabVIEW>\vi.lib\Network\ole.llb. Instead of OLE VIs, use the ActiveX Automation nodes located on the Functions»Communication»ActiveX palette.
Ben
Ben N.
Applications Engineering
ni.com/support
(2,792 Views)
