Need Regeneration in DAQmx write similar to AO write in NI-DAQ
Actually i'm transiting my code from NI-DAQ to DAQmx almost everything working fine with new code in DAQmx.
But i saw an option in AO write that one of its input is a boolean(Allow Regeneration). Now i transitted all my code to DAQmx i need allow regenration boolen option in daqmx so that i can trigger from a subvi to alloow generation to DAQmx write
I'm attaching both the VI's NI-DAQ and DAQmx for reference.Please have look and help me with a solution as early as possible.
(2,670 Views)
Hi abhishek.d,
You can use a Property Node using the Task as the reference and select the property "Regeneration Mode"
Regards.
(2,583 Views)
What's wrong with the solution you got in your other thread?
http://forums.ni.com/t5/LabVIEW/Regeneration-based-on-Boolean-Condition/m-p/2889288
(2,577 Views)
Nothing wrong with ur solution crossrulzz it absolutely helped me a lot and the iisue had been resolved.. This was an earlier thread which is opened by me since i didnt get any response on this thread, by mistake i opened a new thread on the same question and on the same day u solved that issue..
Sorry for multiple threads..
(2,570 Views)
Ok, I didn't notice the original post date.  Well, as long as you have your issue taken care of, that's all that matters.
(2,562 Views)
