Need VI to read Micro-epsilon laser data
Thanks -- yes, please do let me know if the rep has any insight to offer into all of this. I took a quick look at your screen caps, and I can certainly see why you're dissatisfied. In addition to the drift, it looks like you've got a lot of negative spikes in your data -- do you know what's causing that? I'm assuming the Y-scale is volts -- is that correct? Good luck today!
Message 11 of 12
(1,485 Views)
Could you read the laser from LabVIEW? If so... hoy do you send a command as "Dat_Out_Off"?
Thank you.
Message 12 of 12
(1,082 Views)
