Need VIs converted from LV 5.1
Could someone please convert the VIs in the zip files attached from LV 5.1 to perhaps LV 7 or 8? I have 8.5 and can't open them because they're "too old".
(2,759 Views)
Hi Sima,
I can convert these for you, as I have 7.1 and 8.5.1. However, there are many controls missing as I do the converts - so the version in 8.5.1 have large numbers of vi's missing. So a better option maybe to build the vi's in the newer version. Not ideal I know. Let me know what you think, or if you can attach the library which will cause me the problems.
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(2,746 Views)
Hi Hillman,
I don't think I have the missing libraries. I'm trying to find out what's in these VIs. Thanks for trying.
(2,740 Views)
Hi Hillman, could you post the broken updated VIs anyway? I might be able to know what's missing. Thanks.
(2,722 Views)
Hi Sima,
here they are.
Mike
(2,718 Views)
Thanks!
(2,713 Views)
