Need an Oscilloscope.vi with measurement capability
I'm running Labview 6.1 with a multifunction DAQ PCI-6035E board. I need an Oscilloscope.VI that will enable me to measure the time and voltage using cursors just as in an real oscilloscope. There's an example called "2 Channel Oscilloscope.vi" but it doesn't allow measurement. Any help would be highly appreciated. Thanks in advance!
(3,151 Views)
Hi, to get cursors on the graph to read off the time and voltage values, u need to right click on your graph go to visble items and click on cursor legend. this then should pop up at bottom of graph, then with operate value hand cursor, click on the cursor legend it should open up and u should get cursors on your graph and then just read the values off in the boxes on the cursor legend.
Stuart
(3,151 Views)
