Need assistance in making a Cursor or Marker in a Waveform Chart
I cannot find a solution on how to make a Marker or Cursor in a waveform chart. I am recording 12 channels of data and would like to mark certain trigger times I would like to set up a control where the user can set it and another when something has been triggered. I cannot make a graph I know XY graphs have  cursors, I have tried several solutions on trying to plot my data on a chart but it doesn't work in real time, I need to mark my charts in real time. An example would be great. Please if anyone could help I would appreciate this.
(4,051 Views)
I don't think you can have cursors on a chart, only on graphs. Maybe someone else here has some special trick for getting them on charts, and I'll try and think about it too, maybe I can come up with something. But what is the reason you can't just use a waveform graph?
(4,039 Views)
No I tried using a Waveform Graph and it just doesn't work for me.
(4,030 Views)
What about it didn't work? Maybe we can help you get it to work, as it seems like a simpler solution than to try to somehow make it work with a chart.
(4,027 Views)
When I use a Chart it saves the data in real time and does not overwrite the chart in real time, The Graph is just a small portion of data that is being shown in real time. I'm having issues with the graph being read. It not displaying the data like a chart does even if change the settings or try adding buffers, I'm not sure what a solution would be to make the Graph behave the same as the Chart.
On my Graph I measure 12 voltage channels for Y and my X is Actual computer time.
(4,017 Views)
Accepted by topic author Nailer
Try this example and see if it does what you want.
aputman
(4,009 Views)
I forgot about the XY chart buffer, this solved my problem I now have cursors available, Thanks all for the help much appreciated.
(3,999 Views)
