Need assistance with noise filtering on my digital pressure sensor project
"Thank you for your explanations, they saved me. Now I can get the data without zeroing. I can also detect the pulse. But how can I implement the Mean Arterial Pressure (MAP) method in LabVIEW so that it can automatically detect the blood pressure after one cycle of pressure measurement?"
Message 11 of 29
(144 Views)
Hi llimpaull,
@llimpaull wrote:
  • Remove the wait function, VISARead will wait anyway for data on the serial port.
  • Remove the VISAOpen as it is included in VISAConfigureSerialPort AND it doesn't make any sense to open a port in each iteration…
Message 12 of 29
(116 Views)
Sure, but how can I integrate MAP into my system? Last night, I tried to add it but couldn’t find any changes. Does anyone know how to add MAP to LabVIEW and how to use it?
( https://www.ni.com/docs/en-US/bundle/labview-biomedical-toolkit-api-ref/page/lvbiomed/bio_nibp_ana... )
Message 13 of 29
(106 Views)
This is the plot I got with no hand.
And this one was taken with my hand to capture the pulse. Now, I need to create something that can read the MAP from this data. How can I add it?
Message 14 of 29
(100 Views)
Hi llimpaull,
Maybe the first step would be to verify the displayed data before starting any analysis…
Are readings in the range of 4.3e+6 for real? In your Arduino code you seem to scale the reading to mmHg!?
Message 15 of 29
(93 Views)
Hi llimpaull,
You "just" need to collect your sample data in a waveform, then you can apply that analysis function on the waveform…
Message 16 of 29
(100 Views)
No, sir, the data is raw, and I need an accurate system to automatically display the diastolic and systolic values.
Message 17 of 29
(92 Views)
So how can I add this in LabVIEW? I can't seem to find it at all. Also, can I place this in a loop so that each time a waveform is received, it sends it to the system and then gets the result back, and the cycle repeats? Is that possible?
Message 18 of 29
(90 Views)
Hi llimpaull,
Is that possible?
LabVIEW is a full-featured programming environment, so "yes, it's possible"!
Suggestion:
Message 19 of 29
(78 Views)
Hello dear Gerdw
Could you please share the VI file with me?
I’m having difficulty recreating the program from the PNG image you sent.
Thank you for your support.
Message 20 of 29
(59 Views)
