Need certain LED's to turn on when program is run
Guys,
Attached is an instrument .vi that I have been working on.  I was wondering if someone could open it and make the following changes.  I need the following things to turn on when the program is run:
2nd LED of the "Wheel" Button
3rd LED of the "SYNC" Button
2nd LED of the "MODE" Button
1st LET of the "MEASURE" Button
If someone could help me with this I'd really appreciate it....
(2,646 Views)
Why don't you just manually click them on in edit mode, then make the current values default and save the VI?
(2,628 Views)
