Need driver for Pulser-Reciever Unit (panametrics 5900PR)
I have a pulser reciever unit: Panametrics 5900PR.  I can only find a driver for Panametrics 5910PR on the NI website.  Will this driver work for my Pulser-Reciever Unit?  If not, then where can I get a compatible driver?
Software: Labview Professional
OS: Windows XP 32bit
Hardware: Panametrics 5900PR
(3,593 Views)
You will have to ask Panametrics if this will work.
(3,592 Views)
Hey oo77of917,
The Panametrics 5910PR Driver is not listed as NI Certified; which is one indication that the drivers itself was not developed by NI. This being said, I am not sure if the 5910PR driver would work for the 5900PR. If the two instruments are virtually the same, I would guess that most of the features of the driver would still be valid, but I can not be sure. This is why Christian suggest you may want to check with Panametrics to see if this driver is valid and if there would be another driver that would be required for the 5900PR.
Check out this Tutorial for a little more information on instrument drivers.
Duplicate post: 5900 PR virtual instrument code
Hope this helps.
-Ben
WaterlooLabs
(3,569 Views)
(3,565 Views)
