Need help duplicating rows of 2D boolean array
Hi all. I am new to LabVIEW, so I apologize in adavance if my question is basic. I have a 2D array of boolean values. I need to duplicate each row, inserting each new row after it's original row. (i.e.: [a;b;c] becomes [a;a;b;b;c;c]) I am currently auto-indexing the 2D array into a while loop, and trying to insert each auto-indexed row into a new array, but it isn't working... can someone please point me in the right direction? Thanks in advance for the help!
Message 1 of 8
(3,179 Views)
Im relatively new also, so I hope this is what you want to do. Hope it helps.
Message 2 of 8
(3,179 Views)
Thanks for the quick response! I forgot to mention in my question that we only have LabVIEW 6i at school. Is there a way for you (or anyone else) to back save your VI to a version I can read? Thanks!
Message 3 of 8
(3,179 Views)
I would assume that VI's are backwards compatible so it should work considering there are no LV7 features on the VI. Anyway, I saved the VI as version 6.1. Hope it works.
Message 4 of 8
(3,179 Views)
ARRGGGHHHHH!!! When I tried to open the first VI you posted, it couldn't b/c it said that version 7 is newer than version 6.i. Now it won't open the 6.1 VI b/c it says that 6.1 is newer than version 6.0!!!
So apparently I guess I need a version 6.0 VI???
I'm really sorry for the trouble! If you have time to post a 6.0 version, great, if not, I understand! Thanks! (and I hope I can repay the favor one day!!!)
Message 5 of 8
(3,179 Views)
Sorry, like I said, im fairly new to this also and im out of ideas. Perhaps you should repost your question and stipulate the version of VI that you using.
Message 6 of 8
(3,179 Views)
Hi clg6621,
I went ahead and converted the program David had posted to LabVIEW version 6.0. Hopefully this will work for you now without any problems.
Good luck!
Kileen Cheng
Message 7 of 8
(3,179 Views)
Awesome. Thanks to both of yall!
DavidT: It looks like I'm alot newer to this than you are! It would have taken me a while to come up with what you have. Thanks, it's exactly what I need.
Message 8 of 8
(3,179 Views)
