Need help filtering..
Currently I am using LabView 6.1 with a DAQ AI-16XE-50 PCMIA card. I have 5 thermocouple inputs, 3 voltage inputs and 1 frequency input. I need to filter these inputs, but for the life of me I cannot locate and filtering VIs. Is there a seperate tool pack?
(2,802 Views)
Hi;
There is a VI specifically for thermocouples. Look for it in the function palette under:
Data Acquisition -> Signal Conditioning
There are windows and filters under:
Analyze -> Signal Processing
Of course, you can also use the tools under Mathematics, (for example, look under Probability and Statistics) to create your own signal conditioning code.
If for some reason can't find this, probably you have a limited version of LabVIEW.
Regards;
Enrique
www.vartortech.com
(2,802 Views)
