Need help for LV7.1 + DSC; getting variables from TCP/IP VI into DSC module??
A PLC is connected over TCP/IP with the PC where a LabVIEW application runs. The many variables should be managed over the DSC module, the problem is now that I haven´t got any OPC server or something to connect the tags!
So, how is it possible to get the variables into the DSC modul!?
The DSC stuff is a little obscure for me.....................
Thank for help!
(4,167 Views)
What type of protocol are you using to talk to the plc?? There are vi's that will talk modbus to tcp devices directly in labview.
(4,165 Views)
hi there
maybe this product is interesting for you: http://sine.ni.com/nips/cds/view/p/lang/en/nid/11127
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(4,162 Views)
Here is another opc server program.
http://www.kepware.com/Products/products_OPCServers.html
(4,160 Views)
Problem solved, the tag should be connectet to "memory"......................Thanks
(4,147 Views)
