Need help for a more complicated regular expression
Hi everyone,
I got another more complicated one here.
I need to split  '+0,+0.00000000E+000, -4.76517000E+001,-4.64744200E+001,-6.18140500E+001,-5.93055600E+001' by ',' into an array without '+0,+0.00000000E+000'.
I am using a regular expression as  '[+-]([0-9]+[1-9]+)[E][+]\d' but it failed to, just wondering what is happening there.
 Any idea is well appreciated,
+Kunsheng
Message Edited by Kunsheng Chen on 03-05-2009 05:09 PM
(2,961 Views)
Accepted by topic author Kunsheng Chen
Why did you start a new thread?!
Please continue in the original.
(2,943 Views)
First, don't bother with regular expressions. Use the function Spreadsheet String to Array with a commas as the delimiter, %f as the format string, a 1D array of floats as the array type. Next, delete the first two elements from the results and you're done.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,941 Views)
