Need help for encoder count program !!!!!!!!!
I am a new labview user.
And i am trying to complete a project for my course.
For a quick background on what I am working with, I am using a NI PCI-73566-Axis Stepper/Servo Motion Controller for PCI, NI UMI-7764 Series, NI USB-6009 and a IDEC SC1B Rotary Encoder.
I am try to design a encoder count program and a new program to convert the encoder signal to RPM.
But I just don't know where should I start? How can I get the same block diagram like P11 in the attach file?
Please check more detail from the attach file.
(3,478 Views)
The two objects on the block diagram are DAQ Assistants and can be found under Functions»Measurement I/O»NI-DAQmx. From what I can gather, this is acquirign signals that you should have connected to the USB-6009.
-Zach
(3,432 Views)
Thank you very much.
(3,233 Views)
