Need help for using Bundle between two subVis
Hello everyone,
I have two subVis inside a big Vi that need to be connected from one to another.
One complicated thing is that I already have lots of wires in the big Vi, which will become a mess if I connect these two subVis line by line( there will be almost 16 lines between them).
I tried bundle myself but failed couple times(basically I don't know how to connect  bundled wires from the source subvi to the destinated subvi).
Could anyone give me  some idea ?  A simple VI Example would be great helpful.
+Kunsheng
Message Edited by Kunsheng Chen on 03-11-2009 08:28 AM
(3,274 Views)
You should make a Type definition of the cluster, but this is a quick example.  Lemme know if this doesn't answer your question.
I created the cluster in sub1.vi and added a corresponding indicator on the Front Panel & wired it to the Connector Pane.  I made a control on sub2.vi (wired to the connector pane) and wired both sub VIs together in main.vi.  This passes five values through one wire.
Message Edited by jcarmody on 03-11-2009 08:37 AM
Jim
(3,267 Views)
Accepted by topic author Kunsheng Chen
You can get a lot of help from the NI website, too, like this document.
Jim
(3,251 Views)
Thanks a lot man!  It is exactly what I want!
+Kunsheng
(3,243 Views)
