Need help hooking up Omega Vacuum Sensor?
I need some help connecting a Omega Vacuum Sensor (PX141-015v5v) to a Feed Through Module on a SC-2345. I am confused on which wires go where. I am using LabView 7.0 for DAQ. Any programming tips would be helpful too. Thanks
(2,807 Views)
HolzschuM,
You will find wiring information as well as other configuration info at the SCC Configuration Guide.
Here is another link that discusses how to configure the SC-2345 Carrier. If these resources fail to address your concern please post back with more details (which feed-through module you are using, etc.) Good luck!
Craig H.
(2,807 Views)
