Need help im stuck right now
Ramp function didn't work for me.
Message 11 of 21
(1,511 Views)
Smiley IndifferentSmiley Frustrated  Yeah, it can be fickle that way...
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 12 of 21
(1,493 Views)
Hi botenb,
Have you tried using a case structure and shift register to do this? You could use one case for increment, one for decrement and one for hold.
Allison M.
ni.com/support
Message 13 of 21
(1,461 Views)
Im going to try that once I fix one of my other problems.
Message 14 of 21
(1,439 Views)
Why wont this stop when "Numeric" is greater then "Set Point 1"?
Message 15 of 21
(1,416 Views)
Can you be sure your upper inner loop will end?  Comparing two doubles for being equal is generally a bad idea.  They will have to be EXACTLY the same.
Your lower inner loop is completely wrong.   It can never end since its stop terminal is wired from the outside.
I honestly can't figure out what you're even attempting to accomplish here. I suggest some LabVIEW basics to study up on the dataflow programming paradigm...
Message 16 of 21
(1,407 Views)
Can labview read two input signals at the same time?
Message 17 of 21
(1,381 Views)
LabVIEW can.  Whether or not your DAQ hardware can depends on the model.  Most Multi-Function DACs have many inputs but are multiplexed.  If you want to read multiple signals at exactly the same time (no phase offset) then you need a more expensive simultaneous sampler card.
Message 18 of 21
(1,361 Views)
I looked through the specification sheet that I found but it doesn't say IM using NI 6052E Multifunction I/O.
Message 19 of 21
(1,350 Views)
Of course the specifications say!  How could they not???  It's a 16 channel (or 8 differential pairs) model.  That means you can collect upto 16 single-ended signals in a single scan.  There will be a slight time delay between each channel because they're all sharing one ADC and each channel gets multiplexed into it.  That is fine for most applications and is the most common DAQ type from NI.
Keep in mind that since you're sharing the one ADC your maximum sample rate will be divided by the number of channels scanned when you multiplex more than one channel.
Aggregate sample rate = maximum sample rate / number of channels
Message 20 of 21
(1,340 Views)
