Need help in converting old LabVIEW instrument drivers to new version.
I just rented a Tektronix DG2020A data generator. I did not find any instrument drivers for the DG2020A on the Instrument Driver Network, although there are drivers for DG2040 that could be used to some extent. With the instrument, I also received a floppy with example programs. This does include LabVIEW drivers for the DG2020A. However, when I tried to load the VIs, I received an error message that the VI version 3.1 is too old to be converted to 7.1. Can someone at NI help with the conversion? It would be very useful.
Thanks.
(2,610 Views)
There is a driver available for the DG2020 on NI's site. Models supported are the DG2020, DG2030, and DG2040. Available in both 7.x and 8.x.
(2,607 Views)
