Need help in converting string to numeric array
I am trying to convert a string to a numeric array ... the first # in the string gets cut off, the last three seem to come through.
This may be fairly simple, but I really haven't worked with the string functions all that much.
Help would be appreciated.
Message 1 of 10
(7,519 Views)
Hi
You can use "format into string"function from the string function pallet
Message 2 of 10
(7,517 Views)
LabVIEW 2012
Message 3 of 10
(7,507 Views)
oooooooooh
I am so sorry, I did not notice the array" in ur post, because I do not have labview right now, I am very sorry for my last silly mistake
Message 4 of 10
(7,500 Views)
try this ...
(Of course your numbers seem to be fixed with with leading spaces, so it would be also simple to scan using a fixed width)
Message 5 of 10
(7,495 Views)
Wow I sure did misinterpret that one! Smiley Very Happy I guess I paid too much attention to the subject line.
If you remove the first and last byte from the string using string subset then the read spreadsheet string would probably have worked.
LabVIEW 2012
Message 6 of 10
(7,490 Views)
Yup.
Message 7 of 10
(7,481 Views)
Yet another way...
(since you seem to be dealing with integers, I seleted a more logical representation here. modify as needed)
Message 8 of 10
(7,475 Views)
All My Regexes Live in Texas....
Probably don't even need the \h & \v, I just add them as a habit.
Message 9 of 10
(7,469 Views)
Hey guys I appreciate the posts.  I'll try these examples out and see what works with the USB driver.
Great feedback.
Message 10 of 10
(7,460 Views)
