Need help in getting pxi-7854R to build simple code, returns error:-63040
Hi
Trying to build a labview program, which just reads AIO on the pxi-7854R board that is installed in a PXIe=1062Q
Can you help?
below is the error message:
Error Code: -63040
NI-RIO:  (Hex 0xFFFF09C0) A connection could not be established to the specified remote device.
Ensure that the device is on and accessible over the network,
that NI-RIO software is installed, and that the RIO server is running and properly configured.
For NI-RIO 2.3 and later, refer to Software>>NI-RIO>>NI-RIO Settings under the system in MAX.
Prior to NI-RIO 2.3, refer to Software>>NI-VISA>>VISA Options under the system in MAX.
(2,566 Views)
Which NI-RIO driver version do you have installed? Also, this KnowledgeBase article may be helpful in narrowing down the issue:
http://digital.ni.com/public.nsf/allkb/83DF7B9245541FC8862573A100597696?OpenDocument
dK
(2,542 Views)
