Need help in looping
Smiley Sadhi i can read the first data for the first loop. for the second time of loop it read back the first loop data. i attach the vi and the text file with this plz help.
(3,084 Views)
Your program is a mess. you seem to do everything indirectly via value property nodes, breaking all dataflow. This causes race conditions and completely unpredictable outcomes!
For example, have a look at the following code part.
Most likely, the array value will be read at position (2) before position (1) has a chance to update it to the current values.
(In the correct way, you would delete both property nodes and connect the two segments with a plain wire.)
Your entire code has way too many unecessary property nodes and sequence structures and is virtually incomprehensible.
Can you explain in a few sentences how the file should be parsed and what the output should be. I am sure all this could be done with code the size of a postcard and without any sequences and property nodes.
My monitor is not big enough to seriously troubleshoot this program. 🙂
Message Edited by altenbach on 05-15-2008 10:18 PM
(3,074 Views)
erm thks for the reply. i will change it . Actually the problem i facing with the loop is wen passing the 1st loops values and 2 time loop values to write in the database. for the first loop it works well. the second time it loop it write back the values tht in the 1st loop.
(3,067 Views)
the programme actually must read the text file and insert  the values to the database need help plz.
(3,058 Views)
Hi jeyanthi,
what about the solution from yesterday from the other thread?
Mike
Message Edited by MikeS81 on 05-16-2008 08:18 AM
(3,055 Views)
hi mike. i got the the solution redy.but now i have problem passing the values i get to the database.
i dont knw how to pass the 2loops value to the database. It keep on reading the first loops values
(3,049 Views)
Hi jeyanthi,
you have only one value in your first array. Why do you want to split the string with the sign ";"? I thought you need every line, so use code display "\n".
Mike
Message Edited by MikeS81 on 05-16-2008 08:37 AM
(3,042 Views)
