Need help in programming LABView vi using NI usb 6009
I'm working on a LabVIEW project using an NI USB-6009. The VI involves a push button and output channels C0 - C7. When the button is pressed once, it needs to check condition and display the output. If the button is pressed twice, it checks conditions with another set of C0 - C7 values. How can I implement this logic in LabVIEW?
(1,864 Views)
Hi Reddy,
The NI6009 doesn't use channels "C0-C7", it offers the Port0…
What about using a state machine?
What have you tried so far and where are you stuck?
What should happen when you press that button trice or more?
(1,823 Views)
How to produce multiple 8 bit output sequence for single input using DAQ and LabVIEW?
(1,793 Views)
Accepted by topic author Poojitha_Reddy
Hi Poojitha,
Hints:
  • You can use an U8 value to store 8 bits.
  • You can use a (FOR) loop to iterate over each element of an (U8) array…
What have you tried and where are you stuck?
(1,786 Views)
I'm new to labview and know only basics. I don't know how to create the state machine for this. Could you please guide me to create vi for this?
(1,783 Views)
