Need help loading big picture control image on Palm and PocketPC PDA Platforms
Hi Palm and PocketPC LVers:
I need an example program on how to load a ~350K and 3.2Meg picture control format image into a picture control on both Palm and PocketPC platforms.
Any help and suggestions would be appreciated.
Robert
(3,485 Views)
Hello -
Please take a look at the following document: How Do I Put a Picture or Image on My LabVIEW PDA for Palm Front Panel?
I think this might help to get you started.
S Vences
(3,485 Views)
Thanks for the link. There seems to be a 64K limit on the size of the picture you can display on the Palm OS. What is the limit for PocketPC?
Robert
(3,485 Views)
Hello Robert -
I have been able to successfully build an executable with a 243K picture. However, when I ran it on my PocketPC, the image appeared distorted. A 164K picture displays correctly so the limit is somewhere between these values. I will continue to investigate and I will post any further information here.
Hope this helps.
S Vences
(3,485 Views)
