Need help logging from 2 loops
My RS232 signal and analog signals are causing my data acquisition program to display data incorrectly.
The program works best with 2 loops.  If I don' t have 2 loops the data doesn't update on my screen instantly.
I need a way to log the data from both loops.
suggestions?
see attached.
thanks
Darren
(3,142 Views)
First, you should consider using subVIs as well as making your block diagram smaller. The general rule of thumb is to keep the block diagram to a single screen size. With today's monitors that is still a good size for the block diagram. It is too difficult to see what is going on when you have to scroll all over the place.
As to your specific question I would suggest you create a third loop which gets data from a queue. All of your other processes you want to log data would enqueue the data to be logged. The logging process would simply dequeue the requests and write them to the file.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(3,127 Views)
Neat idea.  Are there any examples available where I could see that ?
(3,110 Views)
There are several examples of how to use queues that ship with LabVIEW. Have you looked at those examples?
Mark Yedinak
LabVIEW Champion
(3,102 Views)
In your "ReadSerialBuffer.vi" you should first read the amount of bytes available.
If there aren't any available chars your program will always be waiting at this point.   See the example VISA_RX.vi-attached.
I also advice to use some event case... You could have both loops run one after another in a case structure.  I have attached a serial Port test program I found over here which I like for it's nice structure.
Succes!
X.
(3,101 Views)
