Need help regarding string conversion
Hello I am reading a data from my flow controller and I am getting data and also some square characters. Do I need any conversion here. I am attaching my picture and reference vi here.
Message 1 of 9
(3,582 Views)
What is the reference of your flow controller ? Its datasheet surely explains how to decode the answer...
Message 2 of 9
(3,559 Views)
Right click on that control and select “Display \ codes”, that square character likely will simply turn inti a \r possibly followed by a \n. These are the lin end characters that your device sends at the end to help the receiver recognize that the whole message has been received.
It simply seems to report 100 and then a B that probably indicates a status or similar. The two reported parameters are separated by a comma.
Rolf Kalbermatter  My Blog
Message 3 of 9
(3,556 Views)
I think that both CR and LF are printable as... well... carriage return and linefeed, so they wouldn't show up as oddball characters.  But I'm sure you are right that they are some kind of byte that signals the end of the message.  Since it's serial it might even be EOT (End of Transmission).
Bill
CLD
(Mid-Level minion.)
Message 4 of 9
(3,531 Views)
I'm attaching the manual here. Thank you for your reply.
Message 5 of 9
(3,447 Views)
Hello doc,
did you read this already?
https://forums.ni.com/t5/LabVIEW/Complete-String-Conversion-Tutorial/m-p/4245188
Greets, Dave
Message 6 of 9
(3,399 Views)
Thanks @Dave TW that was really helpful. Also, I think my problem is different I have commands RFS (Reads full scale value of my MFC), RFC (Reads current flow setting), AFC (For adjusting flow setting), I am attaching Pictures of my output here. Currently the problem is if I use AFC command to set value. It's not working. If it works my RFC should change after I set different value using AFC Command.
Message 7 of 9
(3,349 Views)
Please right-click on your string indicator and select "\ Codes Display". Then make the Screenshots again.
Greets, Dave
Message 8 of 9
(3,328 Views)
Here are the pictures as you asked. Thank you for your response.
Message 9 of 9
(3,282 Views)
