Need help resolving build Errors.
I get the following nasty error under application builder (see attached screen shot).  Can anyone help me resolve this?  SS
(2,890 Views)
Hi
I guess it is not possible to build an application containing vi´s without blockdiagram. Are there any Vi´s in your project without blockdiagram?
Mike
(2,881 Views)
This is a common error.  The first thing I would try it disabling "Disconnect Type definitions" under the Additional Exclusions section application properties.  If you are using object oriented programming there might be a different issue.  Let us know if the type definitions trick works.
Eric A.
Distributed I/O Product Support Engineer
(2,856 Views)
