Need help retrieving data from Real-Time Target. Using NI 9233
I have a cRio-9012 with the module 9233. I have just recently setup the software for both the computer and the target. I have also gone through and setup the "NI 9233 Getting started scan mode" to use on my controller. However I have been unable to actually get data from running the VIs. Is there anything that I could have missed?
The VI runs, but it reads a zero while I'm using an accelerometer (Wilcoxon Research Model 797-33).
(2,971 Views)
Accepted by topic author Fulmetalal
You should consider the Labview\examples\compactrio\module specific\ni 9233\ examples.
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
(2,965 Views)
