Need help to find a proper method to detect resonance freq
Hello!
I try to find a resonance frequency from my run-up data.
I have data from 2 channels: TTL and accelerometer. Also, I know the resonance speed - around 720 RMP.
As I know for resonance area the phase should change on 180 degrees but I don't see it from the graph (see attached example).
(3,179 Views)
Without those subVI's it's not going to work...
Sound and vibration toolkit is needed to run this. (Just a warning that downloading is futile if you don't have it).
(3,161 Views)
All subVIs from the LabVIEW Sound and Vibration Toolkit
(3,158 Views)
Is it possible to make Bode plot from this data?
(3,122 Views)
