Need help to find repository's git hub of linux real time kernel of Lavbiew 2018SP1
Hello everyone,
I use Labview 2018SP1 on SOM 9651.
Firmware version 6.5.0f0.
Operating System: NI linux real-time ARMv7-A 4.9.47-rt37-ni6.1.0f0
i need to know where can i download the right repository.
I found https://github.com/ni/linux/tree/nilrt/18.1/4.9 , but i don't know if it is the right.
Is the repository of firmware  in the same folder or in another side?
Best regards
Manuel
(2,217 Views)
If you want the Linux kernel you should be fine. But this does not contain any NI driver software like NI-VISA, NI-DAQmx or the LabVIEW realtime runtime engine. These are not in source code for obvious reasons as they are NI proprietary software.
So what is your reason for wanting to compile your own kernel? It certainly makes everything more complex as you will need to install all NI software afterwards yourself.
Rolf Kalbermatter  My Blog
(2,170 Views)
