Need help to make exe files
I have application builder, but i don't know how to make exe file.
Could you explain me
Best regards
Bill
(2,816 Views)
There's lots of info out there, made somewhat confusing because
Application Builder behaves differently depending whether you have
LabVIEW 4.x, 5.0, or 5.1.
If you're starting with LabVIEW 5.1, I strongly encourage downloading
the 5.1.1 patch
(http://digital.ni.com/softlib.nsf/websearch/8bdc88099bad95db862568730019b7e3)
and then perusing the new Application Builder Release Notes for that
version
(http://digital.ni.com/manuals.nsf/websearch/2ef0fecd178576838625684800791151).
If you have a previous version of LabVIEW, there are also official
release notes for the Application Builder available in NI's Product
Manuals library, but you might also try the Application Builder
Troubleshooting Wizard on the NI site:
http://www.ni.com/support/trouble/labview/toolkits/appbuild/
Best Regards,
John Lum
> Best regards
> Bill
(2,816 Views)
Wait guys,
I think you should wait. I just discovered a little but nasty problem about 5.1.1.
There is something wrong with run time menu. It disappears if you move the
executable from the directory where it was originally built or if you install it
using installer. So there is no way to distribute your application...
Alex Suhisky.
> the 5.1.1 patch
> vers
ion
> Best Regards,
> John Lum
> National Instruments
> > Best regards
> > Bill
(2,816 Views)
