Need help with IMAGE PRE- PROCESSING !!!!!
Hello everyone,
i have a couple of images for which i want to run a Template Matching application.
My issue is for the same object one image has been taken in the day time and the other has been taken in the night. i have also attached the pics below.So naturally i am not getting the desired output in the template matching example.
I shall be grateful if someone can suggest some Image Pre-Processing Techniques so that i can match both the images in the template matching example.
JALASHWA
Message 1 of 1
(2,679 Views)
