Need help with IOLAN serial to ethernet
Hello!
I have a Perle IOLAN serial to ethernet converter and I'm struggling to establish a connection with my serial RS232 device. When the device is connected directly to the RS232 adapter in my PC, everything works great using VISA, so I know the commands sent to the device are valid and the device is responding properly.
I tried two approaches. First, I use Perle TruePort software, which creates a COM port so in principle VISA VIs should work. In this case I immediately get the "The resource is valid, but VISA cannot currently access it." I made sure nothing except NI MAX is accessing it but I still get this error. Second, I tried adding a new VISA TCP/IP resource in NI MAX. I set up the IP and the port and when validating it, I get a "Successfully opened a VISA session to..." message. Great! Then I open the VISA Test Panel, write a command, which results in no errors, however I do see that the device did not switch into the "remote" mode. The read then always times out with the error 56.
I would greatly appreciate any recommendation on what to try next because I'm honestly completely out of ideas at this point.
(1,220 Views)
I'm ashamed to share that the pin mapping on my DB9 was incorrect, which fixed the issue of communicating over a virtual port with VISA VIs. The TCP/IP still doesn't work for whatever reason, so I'd be interested in knowing how to fix that too, but at least I can work with my device now.
(1,203 Views)
Don't be ashamed, things happen and now you learned !
Check the serial port configuration to see it matches your device (baud rate, stop bits, etc).
If still doesn't work, t ry creating a loop between pins 2 and 3 (tx and rx) on the serial port of the Perle IOLAN and remove your device out of the picture (just during troubleshooting).
then send a message and see if you can read it back to check if the device is working properly.
(1,170 Views)
